Any kind of leak even minute would eventually lead to lower coolant levels and if your water pump or anything in your cooling system was bad you car would run atleast a little hotter. My suggestion would be completly flush your oil system then refill with regular motor oil include no lucas stabilizer even though I sell lucas and have never heard of this less variables the better. Then run the car for about ten minutes keep an eye on the coolant and oil level. It wouldn't hurt to drain and flush the coolant system too.
