the bushings are designed for the stock bracket. so you still use the stock bolts and bracket. i'm using mine with no problem
and yeah soak the bolts in pb blaster and then heat them a little. having a friend help is a bonus. i had a friend help by holding the 14mm wrench on the inner part of the endlink while i delt with the nut.
