Deltagate Wastegate Mark II Springs
shaneyeend
241
Nov 26, 2003
laramie, Wyoming
where in the world can i find Deltagate Wastegate Mark II springs? I have the stock 7psi one in it, but need new ones, around 15psi and up
You dont need new springs just throw a boost controller on there, But by your profile i dont see anything for fuel and timing....What are you using if you dont mind me asking?
Oh ok your not just a retard trying to run 30psi like half of the 420a guys on here :p, But yea i would just use a boost controller and that should let you crank it up allot without changing the spring.
yeah i originaly wanted to go crazy with my car now i just want 15pounds to have fun in and maybe turn it up now and again. think i'll get that spring so if i do turn it up the exhaust wont force the gate open
Actually that is impossible :p, Im tired so i dont feel like going in detail but if you study how a wastegate works, You will see what im talkin about :thumb:
In a nut shell a boost controller will only alow you to run double your spring. So you have a 7psi spring you won't be able to run more than 14psi maybe 15 but that would be your max not your street setup.
