Without the ISC, you'll have nothing to automatically compensate idle RPMs for increased electrical load. If you don't mind running a higher idle than normal (probably 1200 to 1500 RPM) and holding the throttle open during warm up, then you probably won't miss the ISC. You can adjust the BISS to increase your idle as needed.
