You can hear it spool but it doesn't pull? I would still check for boost leaks. If a lot of air is leaking out somewhere between the compressor and your motor, then the turbo has to work harder to push out a set psi of boost. This can also cause your turbo to get overworked, and then end up blowing from all the stress. Sounds to me that your turbo is shot, but it could be because of a leak. I'm no expert though, but you should get everything checked out, just to be sure.
Reason: incorrect word choice
