CrazyM
- 409
- 3
- Jun 22, 2006
P.G.,
BC, Canada
Yes I have read, and read and read some more!
I just have a few last minute questions\reassurance points.
I have to port the Outlet of the Exhaust mani(the collector are I believe its called, correct me if I'm wrong please)
I know I have to port the turbo Inlet to 7CM, which clears up room for the gases to have easy access to the wastegate.
Port inlet to this: http://www.vfaq.com/proj-pics/porting/turbo-inlet08.jpg
I have to port behind the wastegate flapper so that it can open the full 90*.
I have to port the O2 housing to get rid of the little lip on the downpipe side.
I am not clear on what I need to port exactly on these places:
The inlet of the O2 housing: This Area----> http://vfaq.com/proj-pics/porting/O2housing01.jpg
For this area, Do I just port out the little bit and gasket match? Do I only gasket match on the O2 Housing side?
Also, the Wastegate hole. How much do I port there? I have the stock flapper still.
My main goal is to eliminate boost creep before I even have it(full 3" Turbo back over winter).
Now if anyone knows I'm wrong in any way,shape or form, please feel free to correct me.
