gmentals
- 60
- 1
- Oct 6, 2005
Hanover,
Pennsylvania
I recently purchased a 99 GSX with a 6 bolt swap. The kid I bought it from was unsure of the mods because he bought it as it is now. It was advertised as having dsmlink, safc II, boost and A/F gauges, rc 550's, a front mount, evo III and a 3" turboback. He also stated that it needed cam seals and that the tach didnt work. When I test drove it I discovered that the front and rear mounts werent bolted on. The car also runs a little rough like it might be missing or has cams. It will occasionally die at a light or when not in gear. I bought a laptop and tried to connect to link but it didnt work. I removed the ecu. It is an eprom and someone wrote "DSMlink- AWD" on the case but it still has the mitsu eprom in it. I then assumed it was running rich with the 550s and no link, so i set the safc to -10% across the board. That didnt really change anything. I am not quite sure what is going on with the car so I removed the mbc and am running off the wastegate. I am looking for someone in the area that has some experience with DSM's that wouldnt mind meeting up and helping me out or just advising me.
! I go back up there every once and a while. Im military and i live in georgia now. keep in touch and ill help you every chance i get when i go back up!
