Hey DSMers,
We are having a special on piston/rod combos. This should cover, for the most part anyway, the 1G and 2G (6 and 7 bolt blocks) combos with 85mm, 85.5mm, and 86mm bores, strokers and standard builds. We are strictly sticking to the brands offered here, with possible additions within the next couple of days. All piston sets come with rings and wrist pins (standard sizes). The amount of power these different set-ups can hold is dependent on type of dyno, fuel used while racing, condition of block being used, and a TON of other determining factors. We'll let you choose which combo you want, just post it up, and I'll PM you the prices, they are starting as low as
$785. If you have any questions, feel free to let me know.
Rods:
Eagle (both 1G and 2G applications)
R&R Aluminum (2G 7 bolt only)
R&R Aluminum with L19 (1G/6 bolt only)
Crower (both 1G and 2 G applications)
Pistons:
Wiseco (standard) 85mm, 85.5mm ,86mm bore
Wiseco (stroker) 85mm, 85.5mm ,86mm bore
JE (standard) 85.5mm and 86mm
JE (stroker) 85.5mm bore
Jerry
