View Single Post
Old 05-12-2008, 08:38 PM   #13 (permalink)
Supa Dexta
Proven Member
Supa Dexta's Avatar
Region: Western Canada
Classifieds Rating: (0)
Reputation: Supa Dexta is an unknown
Ok, So I just went out to see what i could do, pretending the door was stuck shut. Trying to open from the inside without the handle. Is the lock still connected? Can you move the lock back and forth and hear it move within the door? And only the handle isn't working?
If that is the case^ heres what you can try:
The fabric panel above the armrest can be pulled off, the tabs will just pull out and you can reattach it later. Once off there is a hole prob a little bigger then an inch across. Stick your finger in the hole and up, you should feel the two rods. The lower one is the handle the top one is the lock (If need be you could even enlarge the hole some since it's covered by the panel anyways). Using your fingers and a set of needle nose pliers, you can move those rods back and forth. If its just the handle thats not working pull the lower rod towards the front of the car, and it should pop. Let me know, as that will only work if the rods are still in place, and if the lock works.
Offline
[posts] Reply With Quote
Sponsored Links
