JayRolla
- 5,629
- 34
- Feb 23, 2006
Colorado Spring,
Colorado
About the same as a 16g?? I find that hard to believe. I've seen mine side by side with a 16g and there is a huge difference in size. Most others had made *way* more horsepower at similar boost levels than I did with this turbo and they were flowing similar or more air. I'm wondering if its the turbo itself.... I wouldn't mind grabbing / borrowing an Big 16g and slapping it on to test it out juuuuust to see what the flow difference is. Going full 50 or 57 trim is also a possibility.
Also, does anyone know what 650 cc's are good for flow wise? Should I be hitting 90% IDC at 35 lb/min?
If I remember right the v-trim is right below a 50trim and ive seen 16g's flow almost as much as a 50 trim. The v-trim is rated 350-450whp. Its pretty much a evo16g with slow spool.
that was with 93 octane. Maybe this summer Ill throw some in and see what I can do. Right now I turned the boost up to 23 pounds no knock so Ill dyno it when the weather clears. I should be over 300WHP
