Quote:
Originally Posted by cruisintalonawd
I have the palm M100 that it is actually reading only about 1100 whatever at 5000 rpm. The turbo has minimal shaft play and spins freely. I don't have a cat and I've tried driving around without the air filter and that didn't help. I'm not try not trying to me ignorant or anything but I don't think its the boost leaks because they have been the for a while with the car running good
1100 whatever? Please explain what value that is. A log would be nice.
Please explain what you did for your BLT. I'm not trying to offend you, but folks often misunderstand the test procedure and I just wanna make sure you're doing it right. Also, new boost leaks can develop, so if you haven't tested (correctly) since the problems started, I'd re-test.
Did you figure out why the WG wasn't staying closed?
Are there any diagnostic trouble codes stored?
