Mikael SS
- 236
- Jun 10, 2003
San Diego,
California
The setup literally has less than 200 miles on it. Its a 91 AWD that i am brining back from the dead, just freshened up the motor, ported head, 272s, SBR cast manifold, E316g, Front mount, meth inj, 22psi.
When i first got the car i put in an XTD Stage 3 Ceramic clutch, often called an "ebay clutch." It was holding the power fine, and shifting good. The other day i was boosting up in 4th at a lower speed, and all of a sudden the clutch just let go, slipping very badly. You can hold the car still with the clutch out its so bad. I used the TO bearing that came with the clutch kit, not an OEM one.
Is it possible that even though the pedal is coming back all the way the clutch mechanism isn't? Or am i just paying the price for going cheap on an important part?
