Block your fiav and try it again, The fiav raises your idle to 2000 rpms when cold to help warm up your engine.
Block it off, there is a tech article in here explaining how to do it, There are several different way to block the hole, but blocking it off will help this when warm.
You'll know when its blocked off perfect because you'll start the car and it will only be at idle, no higher.
Look it up, and try it. I did it on my car, it made me not look like an a-hole at the stop lights anymore.
