Quote:
Originally Posted by BOC Jason
I'm pretty sure they're just stock.. =/
you can't quote me on that though... lol
but one BIG question i have is...
If iwas to rebuild the turbo... is it just a matter of replacing the little rings and stuff? or do i have to send the turbo out to get balanced and everything?
and if you do have to ship it out then about how much does that cost?
Nope, you dont have to send it out. You just keep the blades inline by using a marker to keep everything lined up. Different kits have different things. I would try to get the biggest kit possible just to make sure. What kind of 16G is it (small/big/evo3)? I'll send you a link of a good rebuild kit. Here's whats usually included:
#1 Journal Bearings
#2 Retaining rings for journal bearings
#3 Piston ring, turbine end
#5 O-ring for compressor housing
#6 Thrust Ring
#7 Thrust Bearing
#8 O-ring for seal plate
#9 Thrust Collar
#11 Piston ring, compressor end
#12 Seal Plate
#13 Retaining ring for seal plate
#14 Left-hand thread locknut for compressor wheel
n/a Oil drain gasket
