Quote:
Originally Posted by TurboTiger
Any results or dyno charts with the JM divided T3 manifold?
The first one will be going on a car running a BW S362, should have dyno #s within a couple weeks.
Quote:
Originally Posted by 99gst_racer
Curious, but why is it not available with twin 44mm gates?
Manifold design and quality looks great, btw.
Link updated
Quote:
Originally Posted by Savage Talon
I see nothing in there for dump tubes, are they available?
Shouldn't be a problem, might need to supply your turbo for proper fitment depending on what you're running. Same goes for o2 housings.
Also looking for fitness in a 1g. Slim line fans needed? Is it going to clear the power steering pump? Does it position the turbo to clear the water pipe? Where's the second wastegate? I only see one in the picture.
Looks like plenty of room for slim fans, power steering pump fitment is fine. Tons of waterpipe clearance. The manifold in the pic is using a single 44mm gate, there's a crossover tube behind the collector so the gate feeds from both sides. I've got a ton more pics showing clearance, I can upload them and post a link soon.
