View Single Post
Old 05-02-2008, 07:03 AM   #13 (permalink)
wt71gas
DSMtuners Supporting Vendor
PerformanceDSM.com
Region: NorCal
Classifieds Rating: (10)
Reputation: wt71gas is more helpful than not
Quote:
Originally Posted by architechnik View Post
Do you have any numbers on distortion levels when working with various materials?
I'm thinking the block and head would be nice along with the all the exhaust components, but if it requires complete rework then it might not be worth it.
Are you guys planning on doing any group buys on things that are pre-treated?
I think this is important so hopefully making it red will make it more visible. CRYOGENIC PROCESSING DOES NOT AFFECT THE PHYSICAL DIMINSIONS OF THE PART WHATSOEVER. Whatever size something goes in, it will come out the same. The only thing to worry about is different materials that expand or contract at different rates during the process. Typically we do the process before the machine work but it has been performed after also and works just fine.
We will absolutely be doing some group buys for this, and the first one will be brake pads and rotors here in a day or two it should be posted up.
____________________________
http://www.performanceDSM.com
530-305-5583
Offline
Sponsored Links
