Quote:
Originally Posted by bboyalan
What's the update on your situation? Also, I was thinking about your boost controller situation. Since you're not sure if your EBC is functioning properly and you don't have your BCS, have you considered momentarily connecting the wastegate's hose straight to the housing?
Well, no I haven't considered that. Would that work though?? I've got a 97 ECU and BCS on the way right now. Should have it all here and in the car by middle of next week. Like Tom and I were talking about on your thread, I noticed this when the PO300 first showed up. For example, I went out and cranked the car today and sat in it for maybe, 2-3 minutes. When I shut it off and went up to look at something on the engine the exhaust manifold was red hot. Nothing else was, just the exh. mani. I already knew I was running extremely lean, my a/f guage tells me that. I just don't know what is causing it. Also, and I have no idea if this has anything to do with it, but before I the car started running like shit and the PO300 came up I was having some weird cooling issues. When driving at cruising speeds the water temps were normal. But when I would come to a stop or a slow roll the temps would plummet. I just assumed I had a thermostat stuck open, but before I could get it swapped out all this happened. Like I said, I have no idea if that has anything to do with this PO300 or not. What do you think?? I wonder if it's possible the fuel pump could start could be going out, but still pumping a little. That would make it run lean. It's something that's not letting the engine get enough fuel. I just don't know what that something is.
