What's the maximum Reliable RPM Limit on the 4G63 Head
marck_c
Nov 6, 2002
kingston, KingstonJamaica
Hi folks. I'm building a high rpm 4g61, with a 4g63 head. I'm curious to know what are your views regarding the maximum rpm limit is, based on the design of these cylinder heads. Please don't flood with comments about not needing to rev the engine high at all. This project is being built for a specific purpose, which necessitates high rpm operation. Look forward to your answers.
The highest i have seen is 10 grand, and it was a street legal car. Tacked out at 10 in first then 9 every gear after that... he ran a 10 sec. quarter mile. it sounded like a rocket, it was sweet
The highest RPM for the head is entirely dependent on the springs, cams, and timing belt. The larger the cams the greater the risk of valve float, where the valve stays open longer than the optimal amount of time. If the springs do not have a high enough rate, then after the cams release pressure the valve will stay open very slightly.
Increase the spring tension/rate and/or decrease the cams then you can keep revving until the cows come home or the bottom end blows out; whichever comes first. The optimal situation would be a conversion to double springs or those with extremely high rigidity and maintain a moderate or stock cam lobe.
The only other concern would be if the timing belt will be able to maintain extremely high RPMs, although a kevlar belt should account for that.
Here is the setup:
The durabilty of the timing belt, and it's accuracy at high rpm, with the attendant stretching issues, were some of my concerns. What rpm limit have you guys seen these belts survive reliably at.
My setup:
Custom 83.5mm 10.0:1 Ross Pistons
Carillo Rods w/ ARP Fastners
ARP Head Studs, Mains, etc
MLS Head Gasket
Brian Crower Stage 3 Cams
Ferrea Dual Interferance fit Springs, w/Ti Retainers
[Adjustable Gears
DNPerformance Tubular Header
FP3052 Turbocharger
Ferrea 1mm OS Valves
Extrude Honed Stock Intake Manifold
Ported and Polished 1g Head
Fluidampr Harmonic Balancer
Custom Moroso 3-Stage Dry Sump Kit
Evolution 8 Intercooler
Haltech E6X ECU
That sounds like a nice setup. I haven't heard of anyone going much over 10k for the simple fact that they're on the downward curve of the powerband at that point and the block/crank/pistons couldn't handle it.
That was also on stock (Mitsu) timing belts, as the kevlar ones I've only seen come around in the past several months. I do not know what kind of duration the upgraded versions can get at those rpms, but the stock ones maintaining were always a concern and caused many broken hearts when frayed.
Likewise with the Cower 3's and double springs, you'll be putting a good bit more wear/tension on the belt, so it may be of concern if you intend to keep it up there for any duration. What were you using this for?
I understand that the original question was about the limit on the head, but high RPM's causes high inertial loads on the rods and bearings too. Please see my StrokeOrNot document ( http://www.kidzuku.com/StrokeOrNot.pdf) for charts on the forces involved.
You don't need to Rev anywhere near 10k for Road Racing.. IMHO
And I will disagree.
Do we know what track he runs? Or what corner he's thinking about not having that extra shift? Or maybe he hits 170 on the front straight, and right now he's RPM limited. :) Point is, he wants the extra RPMs to play with for a reason.
I'm building a head for higher revs and I can think of a couple corners where I'll be able to stay in second instead of the quick upshift to third, then back down to second. That's worth it to me.
Just a thought.
Point taken. I do understand that the higher the rev, the better off you are..
I wouldn't rev past 10k though. That's what i was trying to say, regardless of what type of race it is..
Your forgetting about the 75.5mm stroke and the 83.5 bore.
Well, in drag racing, if you get fast enough, you get to a point where you dont have a chioce with the stock type tranny.
I don't see how the head itself would have some issue at a certain RPM. The head isn't moving; it just sits there and goes wherever your car goes unless your engine falls out or it gets stolen.
You've got the good valvesprings. Get a good timing belt if you're worried about that.
You'd better throw a manual timing belt tension device in there as well. I've seen the hydraulic one compress at high-rpm operation and throw the belt. Also, IMHO, there's better FMICs for the money than the Evo 8 one.
Nope. I'm not forgetting. You're moving air with less velocity using a tiny stroke vs. a stock 4g63 stroke. The stroke determines piston speed. Piston speed determines velocity. The velocity determines the required port and valve diameter. The stock stroke and matching velocity starts to see a mach number that exceeds ideal for the stock valve diameter after 9K with an 88mm 4g63 stroke. So I would assume you're ok, without putting the effort into the math.
