500orbust
- 111
- 3
- Jan 7, 2003
tucson,
Arizona
As the title says, I tuned the car with 93 octane and also 91 octane... What a difference.
With the 93 Octane I was able to achieve 441 whp and 350 tq. This was @ 25 psi and very conservative timing. Im using an aem ems and knock voltage was around 2 volts max. With 91 octane I was only able to get away with 390 whp and 289tq. This run was about 20 psi. Full boost was @5000 rpm and pulls great to 7500. After that the small exhaust housing seems to be in the way.
I tried higher boost with lower timing, lower boost with higher timing, leaner afr's, ect. This was the most i could get away with without getting knock. Im sure I couldve got away with more on 93 octane, but I ran out of gas. This was done on a awd mustang dyno in tucson, az.
Here are my mods:
stock 6 bolt long block - balance shafts eliminated
Aem ems
fic 1150cc injectors
Magnus motorsport -10 fuel rail w/ -6 feed line
255 walbro fuel pump
aeromotive fuel pressure regulator
DNP t4 twin scroll manifold
twin scroll dual ball bearing 61mm - P trim with anti surge housing. Turbine housing is .70
SBR intake manifold
SBR FMIC
Tial bov
3" turbo back
DKS 272 cams
act 2600
I will try E85 soon and I will post the numbers..
Once I figure out how to get the dyno sheets downloaded, I will post them.
If anyone has any suggestions, let me hear them. I would love to make more power on 91 octane.
thanks,
archie
Here are my mods:
Aem ems
SBR intake manifold
SBR FMIC
Tial bov
3" turbo back
DKS 272 cams
act 2600
thanks,
archie
congrats on those numbers, very impressive.
