I would throw 440's in there and call it a day. You'll be able to tune them easily enough with the S-FMU and you'll have a little room to up the boost to maybe 12 or 13psi. You guys both have built blocks right? If you're going to buy new injectors you might as well make a sizable upgrade. Hell, you can probably buy a set of Ford green tops for a V8 and split them amongst yourselves.
____________________________
-Paul
