Quote:
Originally Posted by TSIMonsteR
It takes 5 hands to install this sucker!... lol
Whats the trick?
I started with one half of the "O" assembled and hooked around the internal gate's waste gate actuator without the heat shield in the mix (at first)... line up the other long bolt and start with it part way through the actual heat shield... one it's started, then back out the first long bolt and rethread it through the other half of the heat shield.
Once that happens (and after a few heat cycles) then you might end up in my boat with this:
V V V V V V V
