myblack98gst
- 578
- 1
- Jun 22, 2003
Elizabethtown,
Kentucky
I did not even know this was happening till installed a DIS-2 after messing with that for a week I ended up taking it off assuming it was bad. after removal I did a log on the car and this is what it came up with.
rpm --- injp --- injd -- mafs
5625 - 10.49 - 49.2 -- 1163.6
6000 - 11.51 - 57.0 -- 1390.0
6281 - 11.77 - 61.7 -- 1478.1
-------- 9.98 -- -------- 1534.7
7812 - 10.75 - 69.5 -- 1603.9
7968 - 9.72 --- 64.0 -- 1503.3 <---end of pull let off gas car will go to 8,500 no problem
WHERE did the info go!!! I have several logs that cut off right at 6281 on the dot. BUT I cannot feel a studder or miss while making a pull at all it goes right past this with no problem. IF the MSD is on it however I get the same results at exactly 6281 BUT the LED light on the MSD goes off and the car starts to buck and wont pull past it.
what I have done.
replaced:
CAS
Coils (now running a evo ignition (same problem before))
wires of course
tested
all wires for CAS all show good for impedance and voltage
inspected harness for apparent problems cannot find anything
hook a VOM to the MPI relay on he 12volt outputs it holds voltage even when the signal is messed up.
I am just about lost at this point I do not know where to go on. does anyone have any insight as to what this could be or have had a similiar issue?!?
WTF
what I have done.
replaced:
CAS
wires of course
tested
WTF
