Finally the group buy you guys have been waiting for, the DSM 20g-6SL2 now for $899.00! Included in the group buy are:
7cm DSM Gasket Set
Male Style T-Shirt OR
Womans underwear -
Boy Shorts,
Invisi-Thong, or
G-String
Polished compressor cover shown on the picture. (add $95 for polished)
Here is some info on the 20G - The Street/Strip 20G is the most highly evolved turbo in the 20G line. It features a 3" inlet compressor housing, and the newest TD06SL2 turbine wheel for the best combination of response and top end horsepower! The Street/Strip 20G works best in combination with external wastegates, but can also be built with an internal wastegate setup if required.
Turbine housing port job is included in the price of the turbo, specify whether you run your external wastegate on the O2 housing or manifold. For an additional $150 internal gate with 34mm flapper can be added. Chrome plated compressor cover optional $95. 90 degree compressor outlet pipe can be add only on the non-polished cover. Compressor elbow is an additional $95.00.
Forced Performance 20g-6SL2 turbocharger
