Multiple engine issues
TSiWith17PSi
Apr 11, 2005
Eustis, Florida
Let me start off explaining what mods I have, as this may help with opinions. I have a 9:1 Wiseco/eagle 2.0L motor. I have an eprom ecu with stage 3 chip set for 780s with a set of PTE 780cc injectors. My turbo setup consists of a t3/t4 SC 61. Now onto my problem. I recently had an issue with my car running extremely rich, even though my car ran well previously with this same set up. The only thing I did was swapped my 50 trim for the turbo that is on there now. With the new turbo, my car runs like garbage. I have checked for boost leaks and fixed the minor leaks I did have. However, the car continues to run very rich. It seems as if the car is just dumping fuel as it boils out black smoke. This was never an issue with my old turbo set up. Earlier today I was outside putting a few things back together, and noticed that every time I tried to rev the car the motor would bog down when on WOT. The car revs like normal if I gradually increase the throttle with the exception of a raspy like sound. Any help would be greatly appreciated.
