squeak10686
- 360
- 1
- Jul 18, 2004
omaha,
Nebraska
Hello..
I've been looking into DSMLINK and have a couple questions for you guys...
1st of all the full throttle tuning doesnt look bad at all and in fact is pretty straight forward...
the real questions I have for you guys is this... if you are to rev a motor above 8000 RPMS how do you compensate for that???
HOW DO YOU TUNE FOR PART THROTTLE??? to lean the car out on the interstate for better gas mileage ETC!!!
and lastly for timing, if I decide to pull 1 deg. of timing at 4k rpms this does this at all throttle positions correct??? so even at part throttle I'm going to be comprimising my fuel map??? how does this affect driveability...
basically I'm asking this... If I throw 1000cc injectors in my car with a T67 with twin walbros and a GM MAFT... will i be able to drive this Turd around on the street and tune it for DRIVEABILLITY!!!!! not just wide open throttle...
and how do you tune the driveability????
thanks so much guys!
Andrew.
Andrew.
