Scrymerr
- 1,367
- 4
- Sep 22, 2002
Vacaville,
California
I am attempting to take my car to a track day at Infineon Raceway for the first time. I have read through quite a few threads, and found a lot of great information. I would like to share a few details of my setup and get some advice pertaining more specifically to my car and me.
The first concern I have is the fact that my doorhandles are shaved. I understand the need for doorhandles to function correctly in case of an emergency extraction or such, however some cars such as the C6 corvette have buttons instead of handles; what happens in a crash if the car loses power. This no doorhandle issue would be an even greater concern of mine, however I have T-tops. Tops are required to be removed for racing, and the windows rolled down. What are the chances in this case that I would be allowed to run with shaved handles?
Also, the car is street driven pretty frequently with a very conservative 350whp tune. I am in no way worried about the power levels, but my suspension setup bothers me. I am running tein basic coilovers with upper pillowball mounts, stock swaybars, SPC front control arms, Rotora BBK, and BFG G-Force 255/40/17's. Right now I have about 1 degree of negative camber all around, with a little bit of toe-in in both the front and the rear. My questions:
What would be the recommended alignment for tracking the car, keeping in mind that the car is street driven about 300 miles a month?
What tire pressure should I run?
Should I make any adjustments to the ride height?
Other than that, I would appreciate any other suggestions. After reading quite a few threads, I have notices the stress drivers place on the cooling system, aero, and 'reliability'. The car is put together very well: I loctite just about everything, my cooling system is in order (and had no problems last summer with 100 degree outside temperatures and pretty much20 solid minutes WOT and >6500 RPM), I have no fluid/vacuum leaks, and my brake pads and tires all have well over 80% life left.
I will start with this, see what kind of responses I get, and see if I can make some beneficial changes over the next few weeks.
Thanks in advance,
Dan
Thanks in advance,
Dan
But, the experience gave me an idea of what the car needed for my particular track.
