View Single Post
Old 03-06-2008, 05:05 PM   #1 (permalink)
maperformance
DSMtuners Supporting Vendor
MAPerformance
Region: Midwest
Classifieds Rating: (16)
Reputation: maperformance is an unknown
Competition Clutch Clearance Sale / Huge Discounts Until We Run Out!
Stage 2 - Street Series 2100 Clutch Kit
This assembly provides approximately 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life.
The 2100 Series kit includes a performance pressure plate, a high torque sprung disc with antiburst steel backed Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool.
Stage 3 - Street/Strip Series 2300 Clutch Kit
This segmented Carbon Kevlar material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. 500 mile break-in REQUIRED with this set-up.
The 2300 Series kit includes a performance pressure plate, a high torque sprung disc with segmented Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool.
Stage 4 - Strip Series 1620 Clutch Kit
This assembly, available with a double spring, six rivet carriage or six puck rigid plate is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 250% increase in torque capacity.
The 1620 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
Stage 5 - Strip Series 1420 Clutch Kit
This assembly, available with a double spring, six rivet carriage or rigid plate is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 300% increase in torque capacity.
The 1420 Series kit includes a performance pressure plate, a four puck high torque sprung disc Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
*Please note that these part numbers (1420, 1680, 2100, etc) DO NOT indicate the force of the pressure plate!
Please contact us for special DSMtuners pricing and information!
____________________________
Chris Carey
AIM: maperformance1
Offline
Related Auctions
Sponsored Links
