chowda633
- 169
- 3
- Dec 31, 2003
Newport,
Rhode Island
Its a brand new 1G that was in the car when I got it. Had a plug on it too that looked like it had been cut from somewhere else. Had a red and a blue wire and it was a new plug.
I guestimated the wiring of it because the car harness is black on both. One wire was bigger than the other and the same on the alt. So I wired the big to the big and the little to the little.
I got the car running. It runs mint with cables connect but as soon as I disconnect it starts to loose power and run all wacked out. No check engine light though.
Dam does it run mint though when I have the cables on it.
Now the alt. was in a fire at some point because half the harness is melted and I am wondering if there is a short in there? I figure if I wired the plug backwards it would catch on fire? Alt fuse was fine before I started it up. Have not looked at it since. I don't believe the car will start with out it. The battery is holding a charge now also. Threw in a dead yellow optima and brought it back to life.
So throw me some ideas here?
Hack up the wiring? It seems that it was a black pool of plastic at the bottom of the alt harness also. The round metal loop that holds the harness in the air is not even there that connects on the back of the alt is gone.
*Update*
Checked out the wiring but it seems fine. The plug has a red and a blue wire. Don't want to risk swapping them. Alt fuze is fine. What am I looking for on the volt meter down there?
*Update*
