2g mas installed. Random stalling. Tuning problems...?
Vehicle is a 1991 tsi awd. Main mods are:
Custom intake for 2g mas
Fmic w/ 2.5" ic piping
Rewired Walbro 190
SAFC2
Evo 560cc injectors
Evo3 manifold
Small 16g
Apexi DP and Exhaust
Boost is at 15psi (may be irrelevant because I'm worrying about low throttle)
I just installed a 2G MAS and bpr7es and I'm having trouble keeping it running. The idle is perfect and boosts fine, but when I'm cruising around 1500-2400rpm, the stock boost gauge will jerk to 14 and the car will try to die. Also, when I release the gas it will sometimes try to die as the stock boost gauge jerks up and back down to normal.
The problem is not the wiring or the Mas. I changed to another mas and triple-checked my wiring. No boost leaks.
Could this be due to my safc settings?
800>-18
1400>-14
2000>-6
2800>-4
.. the rest are -4, as well as high throttle
What I did was tune the low fuel trim to 100%. I was looking at other similar threads (there are so many, but none has this jerking problem) on here and dsmtalk, and some people with 550cc injectors have their settings in the positives. Could my setting be Really lean? I understand that all cars are different, but why does mine need to be at -18, whereas others are in the upper positives?
Could a lean mixture cause this jerk on the stock boost gauge? I may try richening up the points tomorrow (don't wanna wake the neighbors).. I wish I was out right now at the big dsm meet, but this problem had to occur.
Thanks in advance
