View Single Post
Old 02-07-2008, 10:58 PM   #202 (permalink)
ceedawg
Proven Member
ceedawg's Avatar
Classifieds Rating: (0)
Reputation: ceedawg is an unknown
Quote:
Originally Posted by dsm-onster View Post
No one knows. . . You'll have to test it out. Holset housing almost forces one to run a better o2 housing design. . . That DOES count for something . . .at the hx35 flow level. Who knows? Only a log will tell.
Well I have my hybrid turbo right here next to my new HX40 pro with the 14^2cm custom holset turbine housing. This Turbine hsing is rumored to be a .97A/R hsing.
The only thing I'm not to crazee about is that the outlet is a lil less than 2.75 inches compared to 3" on my BEP housing mounted on my HX40/35. I'm still going with 3" on my downpipe some how when I have it fabricated for this Holset hsing unless I get a 16^2cm hsing which I believe has a 3" outlet.
The difference in the overall size of the housings is very very apparent. This 14^2cm housing nearly dwarfs this .55AR BEP housing.
I wonder if this Holset 14^2cm hsing will also dwarf the .70A/R T3 divided hsing BEP has now?
I guess I'll be looking for some nice top end and spoolup from this thing since it's a divided hsing and I plan on using a exh mani with a divided outlet to match. Runners 1&4 and runners 2&3 separated and situated together at the collector flange.
PICS will be posted to compare.
Offline
[posts] Reply With Quote
Sponsored Links
