91GSXeclipse
- Sep 25, 2005
Lincoln,
Nebraska
When at idle (usually at warm up and during turbo time) the car will go back and forth rich and then lean usually 11 afr to 16 arf. The car is tuned perfectly and will sit at stoich most of the time but every once in a while it will go rich and then lean. The car idles normally with no error codes and no obvious changes on the logger? I have been told that a leaky TB can cause weird conditions like this. I havent completed a boost leak test since I installed injectors, im not sure if a vacuum leak would cause this condtion though.
