2G [RESOLVED] What is this thing? Imasen, E8T08474
EricGRIT09
86
Nov 15, 2006
Syracuse, New York
So here's the story. My taillights, driver side marker light, and dash lights all worked sometimes, and not other times. This has been going on for about a month now, so my dad and I started working on finding the problem tonight.
Well, as we were checking wires and grounds my dad took a bunch of ground wires and touched them to what he thought was a ground wire in the fuse box. Turns out it was the positive side of the 60Amp Fusible Link. :tease: A quick pop, and the horn just stayed on. Headlights also. Radio doesn't work either.
Now here is where it gets weird. When the headlight switch was on the 'on' position, there was a clicking sound coming from the radio/ecu area behind the dash. At first we thought the ECU was toast, as disconnecting the large connector on that made the clicking stop. Finally, we found the real reason for the clicking. Some weird bronze box right next to the ECU, on the passenger side.
Made by Imasen, it is stamped with 'E8T08474' and '5213'. Most information I found was that Imasen makes 'seat' products for Mitsubishi. Any help would be appreciated, anyone know what this is?
P.S. Sometimes my horn just stays on now, along with the headlights (with the switch off). I'm going outside to check it out now, but anyone have this happen before?
-Thanks in advance.
Yes it is out of my 95 GSX.
Thanks for the help guys, noobie question, but nothing led me to know off the bat that it was the MPI relay.
Well, things seem to be working on my car again, but kinda off and on, hopefully the ECU isn't fried, haha.
Engine not firing/running - yes. Not cranking - no - that would be poor battery or battery to starter and ground connections bad or battery cables bad or bad starter. But most of the time its poor connections or battery.
