Quote:
Originally Posted by mach4g63t
Yea, you'd have to do a blow thru setup or use a 2g MAS.
As Robert mentioned above, with the 1Gs there is not enough room in the fenderwell for the MAS (1G/2G) + airfilter. On my 1990 w/ 2G MAS I had ~2" clearance with the pipe to my headlight motor assembly so could not use. With a GM MAFT in blow thru, VPC or MAP-based standalone, will have ample room for the pipe+filter.
