Thread: Evo III on 420a
View Single Post
Old 01-07-2008, 08:25 PM   #19 (permalink)
BigRand
Proven Member
BigRand's Avatar
Timeslip: 14.337 @ 98.390
Region: Eastern Canada
Classifieds Rating: (4)
Reputation: BigRand is extremely helpful and trustworthyBigRand is extremely helpful and trustworthyBigRand is extremely helpful and trustworthy
Quote:
Originally Posted by DSMGRUNGE View Post
OK...I found a hahn 16g to use for my setup. I have also been reading about the portfueler. I know I don't need it for my HP goal but maybe later with some forged internals it wouldn't hurt. I have read alot of favorable reviews on MSnS but my technical skills are zip and I know a guy wanting to get rid of his Portfueler that I can get CHEAP!!!!
With the portfueler I need what? A 1:1 FPR and my walbro 255? Do I still need a FCD? I have so many questions and so many more coming as I get to my install. Also with the portfueler, would it hurt to run it now or should I just stay with a 12:1 fmu? Thanks for all the imput
Are you planning on building the motor? Because if not I wouldn't usually suggest any of the fuel setups you mentioned other than the FMU if your staying under 9psi. (if you plan on pushing the stock block then I understand) But to me it sounds like your Money is not as your disposal.
My next option would be MSnS, but that requires some fine tuning, but it woudn't be a bad idea on the stock block with lower amounts of boost.
____________________________
-Randy: Boosted since 05/05
Offline
Sponsored Links
