Interesting problem I ran into ordering these 94 axles with the bigger spline...nobody seems to have a different part # for 1G's,they all will ship the smaller splined axles even if you ask for a 94 set.
Carquest showed a difference in parts but its the difference between an Eagle and a Mitsubishi for 94 ...I told the guy there should be no diffrence but lets try anyway.I got only one axle first and although it fit perfectly,the threads for the axle nut were destroyed so another ones on order.
To Recap,If you put a 93-94 motor in and you need these axles,call Carquest and order them for a 94 Mitsubishi 2.0 turbo FWD
Drivers side - Carquest part # CV2199
Passenger side- (will post when it arrives or I find the reciept)
