View Single Post
Old 01-03-2008, 10:32 PM   #3 (permalink)
Slippi84
Proven Member
Slippi84's Avatar
Region: Tri State
Classifieds Rating: (7)
Reputation: Slippi84 is pretty helpful and trustworthy
Quote:
Originally Posted by PieEyedPiper View Post
Many enjoy a lightened flywheel, though too light is counter productive in some circumstances. I like the some of the heavier-light flywheels that hang out around 12lbs. 7lbs seems to be too light according to some members.
I'm curious though, if you're not going to boost that 420A of yours, why do you want a clutch designed for triple or even quadruple the power output of your car?
EDIT: It just dawned on me why you might have taken interest in that particular clutch. I found it peculiar, myself being a SPEC Stage 2+ owner (good for 415+ ft.lbs of trq.), but it stands to reason that not all Spec 3+ clutches hold the same power, or even close. I would guess that SPEC, like many companies, lay out a product line for each individual application in such a way that uses the same terminology for "stages" such as the "Stage 3+" but they may have dramatically different, and proportionally appropriate holding capacities.
i.e.
The 4g63t might have 3 clutches available from company A that range from 240ft.lbs, 350ft.lbs and 450ft.lbs of trq. capacity.
The 420A might have 3 clutches available from company A that range from 150ft.lbs, 200ft.lbs and 300ft.lbs of trq. capacity.
However, the nomenclature remains the same for each "stage" while the application changes - determining the holding capacity of that particular clutch.
I hope that makes sense. This idea was kind of difficult to type out.
btw, nice build on that 420A. What are your goals?
Thanks and your 100% right on everything you said. My goals are small nothing big... just to be the fastest non turbo eclipse with the aid of nitrous. I know some consider it cheating but I put turbo's in the same boat as nitrous. Technology at work in a nut shell. I"m looking at a 2 stage nitrous setup equaling up to about 400whp whatever it takes to make that is what i'll spray.
By the way a spec stage 3+ holds 475ft/lbs trq. I could probably get away with a stage 3 but a stage 3 is a sprung 6 puck a stage 3+ even though a lot more money something like 120 bucs is a street disk that's sprung making it more streetable and this car will be dd
Offline
Sponsored Links
