what he said is very ture. also make sure that you alternate the gaps in the piston rings! if they all get aligned they will blow out oil like crazy! Check the pistions to see if this is what happened the first time. Also look to see what caused the failure the first time. personally i would not put it back together till i found out what happed and made sure that it did not do it again as it takes a lot of time and money to redo these kinda things
