Ben
- 119
- Nov 25, 2003
Lubbock,
Texas
I have a 91 5 speed GSX with an e742 EPROM in it. My car has 91-94 coils/power transistor. I didn't even notice that an e742 was for 90 models until I started ordering my Keydiver dsmchip today. does this affect anything?
I also have the correct EPROM ECU for a 91, but it's nasty on the inside, and the 90 EPROM looks brand new, so I want to use the 90 EPROM ECU if possible.
I did a little searching, and I found where someone said that you don't have to do anything to put a 90 ECU in a 91 car, just swap 2 pins on it to fix an idle issue. is this true? What idle issue is it? Of course I drive a DSM, it doesn't idle perfect but if this is the cause of a small idle issue that would be AWSOME.
Thanks for the space.
, do it at the ecu...it will take some time, but it's worth it.
) with full size hands with plenty of room to work.
