selmerguy
- 1,811
- 23
- Nov 14, 2004
Killeen,
Texas
I am going to have my last try at the track this weekend. I got the car running pretty good aside from the occasional IC pipe getting blown off. While tuning I am curious about what is more important for power timing or afr. Should I tune for the 11.1:1 afr and pull timing so I dont get knock or run richer and get 20 degrees at 7000 rpm. The only way I get to 20 degrees is if I run about 10:1 AFR. Which way makes more power?
. Next get a baseline A/F ratio based on fuel (pump gas: tune to 10.5:1). Then focus on timing. Add a degree at a time until you see knock (timing retard). Then move to the next timing point to create your curve. After that go back to fuel and lean out at each point just before you see knock. You may think that you can't lean her out a little more once you've adjusted for the most agressive timing curve, but you can. Just focus on small incriments.
