becareful with the the Neon Block being called the same. That statement is not altogether wrong but not altogether correct.
The Neon 2.0 DOHC bottom end is a direct fit for your 2gnt. Compression is the same; however the PCV system in the 95 was different. The PCV lines entered the block in the front with 2 large lines. These need to be capped off in our cars.
The Neon 2.0 SOHC bottom end is different but will work. Compression is lower, pistons are different. Again the 95 block had the different style PCV system that needs to be capped off.
All neaon heads are different and wont work without a lot of modification.
Terry
____________________________
MS powered 2.XL
