What lb/min are you flowing on pump & bigger turbos
New set up is in so it's time to report in again
2.3l
unhacked 2g mas
ported 2g head w/ 1mm OS valves
cyclone that is running all 8 runners all the time right now
272's
3076r
52.7 lbs/min @ 24 psi. It was about 35 degrees out as well.
50 lbs/min not very good tune but calibrated maft with dsmlink and pte 6031 (60-1)
daily 41 lbs/min on ~17psi~
I wanted 50 now I want 60. The sickness gets worse....:coy:
Isnt a good horsepower calculation times your lbs/min by 9 and that gives a close hp number?
I did find a boost leak, and was and still am pretty much uncalibrated. Soo yea my air flow #'s were most likely a little off.
I got tired of trying to get the LTFT and STFT close and gave up. Made a small correction and left it alone. I need someone to tune my car for me LOL.
1g talon auto 69lb/min gas 95oct. turbo hta37 36psi. I think it's enough for street ;)
The last post in this thread was made over 11 years ago, some 6 months after you joined the site. Back then running 18psi on a 50-trim was pretty daring, and getting anywhere near 70 lb/min on pump gas was impossible due to tuning limitations.
Pay attention to thread dates ;)
