View Single Post
Old 10-27-2007, 04:45 PM   #9 (permalink)
nanokpsi
Proven Member
Region: Gulf Coast
Classifieds Rating: (2)
Reputation: nanokpsi is pretty helpful and trustworthy
Quote:
Originally Posted by pnishr View Post
I'm thinking "not so much..."
Rod Ratio of 1.44 (if they use "stroker pistons" and a 153mm rod)
That's worse than a 2.3l stroker (at 1.50)
I don't think I'd be comfortable taking that above 7500... if that. But, as stated, it could be cool on the street with a mid-sized turbo that it could spool quickly.
IIRC you end up losing around 500 rpm to a 100mm crank as far as piston speeds are concerned which isn't a huge deal. It might not be worth it in the end for that ~10% increase in motor size though.
Offline
[posts] Reply With Quote
Sponsored Links
