Remove the sway bar brackets by removing the sway bar bracket bolt. These are 14mm bolts (circled in red) and can be removed on with a 14mm socket and ratchet. There is only one bolt per bracket with one bracket on each side of the car (drive side and passenger side shown). This will give the sway bar enough room to get to the foward bolts of the power steering bracket bolts (next step).
____________________________
Sean B.
