Thread: keydiver/afc
View Single Post
Old 10-15-2007, 11:52 AM   #9 (permalink)
DGajre777
DSM Wiseman
DGajre777's Avatar
Region: Southeast
Classifieds Rating: (14)
erald01 - As for your original question -
"Do I have to use an AFC with my chip?
Generally, yes. Although the changes I make to the Global Fuel and MAS Compensation get VERY close, and make it easier to tune, it is still recommended that you have some tunability, such as an Air-Fuel computer or a GOOD adjustable Fuel Pressure Regulator. In addition, every car is different, so you may require more/less fuel depending on your situation - www.dsmchips.com
Basically, if you see knock on your boost gauge (that hopefully you had burned to see knock sum), then either turn the boost down or bump up the fuel pressure.
And if you don't want to use the formula, here are the numbers from the DSMLink manual.
Size (cc/min) Global (%) Dead time (ms)
RC 550 -18% 180
Hahn 625 -18% 180
Denso 660 -31% 180
Denso 720 -38% 450
PTE 580 -16% 180
PTE 680 -30% 210
PTE 780 -40% 315
PTE 880 -46% 330
FIC 650 -31% 315
FIC 750 -40% 315
FIC 850 -47% 315
FIC 950 -53% 315
Quote:
Originally Posted by Black_Bullet View Post
I agree about the logger, and a wideband should be thrown in with that list as well.
Or just ask Jeff at DSMChips to burn your chip with the A/F ratio that you want to run (for example 11.5:1 on 93 octane) and you won't need to get a wideband.
I run the n/t fpr at 48 base psi, it lowers fp over run a good amount and makes your injectors flow like there bigger. But i wouldnt run this fpr if you plan to run beyond 25psi because fuel pressure relief valve will kick in at that point.
The original poster has an AFPR, he won't need to worry about stock fuel pressure regulator overrun.
____________________________
Dee.
Offline
