Thread: keydiver/afc
View Single Post
Old 10-15-2007, 07:36 AM   #6 (permalink)
Black_Bullet
Proven Member
Black_Bullet's Avatar
Region: Southeast
Classifieds Rating: (0)
Reputation: Black_Bullet is more helpful than not
Quote:
Originally Posted by erald01 View Post
i was just wondering, do u really need and afc with the keydiver chip, cause i got my keydiver and im about to install it but i dont have an afc or a datalogger. i think im gona get a dsmlink down the road. i dont think there should be a problem with the car running without the afc should it? my upgrades are
evo3 16g
evo3 manifold and 02 housing
afpr
650 fic injectors
walbro255lph
fmic
3" apexi
Yes that set up will work fine, but why not get bigger injectors... Get the 850s at least
why hold your self back since you have a means to control them all the same...
Quote:
Originally Posted by 16gpoweredgsx View Post
You should't need to use a safc, as long as you chip is setup for your mods, you should be fine. Although you should get a datalogger a.s.a.p., so you know what your car is really doing and how it will react to the mods.
I agree about the logger, and a wideband should be thrown in with that list as well.
Quote:
Originally Posted by TunaTalon View Post
Expect the Keydiver chip to be very close. I ended up with 42.5 PSI base fuel pressure on my tune with 720s.
If you want to change later the $20.00 charge for a reburn is cheap , even for DSM'ers.
I run the n/t fpr at 48 base psi, it lowers fp over run a good amount and makes your injectors flow like there bigger. But i wouldnt run this fpr if you plan to run beyond 25psi because fuel pressure relief valve will kick in at that point.
Quote:
Originally Posted by bling5tatus View Post
Does Jeff compensate for inj dead time or just the size of the injectors? Does he ask specifically what brand/size the injectors are or just what size they are?
Just be specific on telling him your goals w/ the car and what parts you have in the mix.
He does compensate for inj dead time and global and all that, you can go on dsmlink boards and find out what your deadtime and global % should be for your injectors/fuel pressure and ask him what he had in mind and compare and see if thats the amount of deadtime you want. Or if you dont feel like looking i believe the global formula is
450 / (inj size you run) / 1.2864 - 1.0 = _________ - 1.0 = ( This would be your global %)
Mines is at like 315 us inj dead time w/ 41% global, i burn my own chips so im going to lower my dead time to 310us on my 850s... Wont change much but generally the higher the deadtime number the richer the burn, the lower the leaner.
____________________________
((Jay))
E316G - 6bolt/4bolt
Offline
[posts] [gallery] [blogs] Reply With Quote
