View Single Post
Old 10-11-2007, 04:31 PM   #1 (permalink)
extremepsi
Vendor/Site Sponsor
ExtremePSI
Region: Tri State
Classifieds Rating: (0)
Reputation: extremepsi is an unknown
ARP "L19" Headstud kit now available ready to ship!
Hey Everyone,
After 6-8 long weeks of waiting for these bad boy studs, they are finally here. We will try our best to keep them on the shelf at all times as well.
ARP's L19 material (comparable to A1 Technologies H11 Tool Steel) is a premium steel that is processed to deliver superior strength and fatigue properties. L19 is a very high strength material compared with 8740 (standard ARP headstuds) and is capable of delivering a clamp load at 260,000 psi. It is primarily used in short track and drag racing applications where inertia loads exceed the clamping capability of ARP2000. Like most high strength, quench and temper steels - L19 requires special care during manufacturing to avoid hydrogen embrittlement. This material is easily contaminated and subject to stress corrosion. It must be kept well-oiled and not exposed to moisture.
Because of the many head lifting issues on 4G63 blocks running in excess of 35+ PSI, a stronger stud needed to be manufactured to meet the demands of today's top engine builders and racers alike. Typical lead time on these studs is 6-8 weeks, but we have ordered these in advance and will be shelf stocking them! The L19 head stud upgrade comes with Studs, Washers, and Bolts for a complete installation. No Modification to your cylinder head or block is required as these are a direct drop-in replacement for the OEM head stud!
Yield Strength: 200-230,000 PSI
Tensile Strength: 260,000 PSI
*Note: The nuts and washers included in this kit still utilize premium grade 8740 alloy as only the stud is subjected increased pressure. ARP Moly Assembly Lubricant also included in kit.
ARP "L19" Headstud Kit: Mitsubishi Eclipse 6-Bolt = $289.95
ARP "L19" Headstud Kit: Mitsubishi Eclipse 7-Bolt = $235.50
Thanks,
Hung
Extreme PSI
____________________________
Thanks,
Hung
Extreme PSI LLC
Offline
Related Auctions
Sponsored Links
