mharrison
- 45
- Feb 7, 2006
Madison,
Mississippi
also you could check the cam angle sensor, this tells the injectors when to spray fuel. simple check you could unplug it after its running, and it should work in the open loop function, where the injectors are constantly spraying fuel. but if it makes no difference in the idle you might have found your problem. just an easy check to rule that out.
The above is from another thread. When I unplug my Cam Angle Sensor, the car just dies immediately. Does this mean it's bad? Or is the above test not valid?
