TERBOLASER
- 183
- 4
- Jul 22, 2003
greensboro,
North Carolina
okay i got my logger in and efi pms is in the car now im running a 3 inch cat back 14 b turbo piped with 2.5 inch upper IC and 2 inch lower going thru a FMIC mashimotoand all was running fine untill today . Im getting crazy low rpm part throttle knock like form 2000 up on the logger. it goes from zero knock and spike for 43 ( which when i see naturally i let off. ) what I realized is weird is that if I i go wide open throttle i dont have any detonation count period. but the point is it is detonating and its bad when i finally got home after doing the whole let off the tthrottle coast the car home thing i popped my hood and the manifold was glowing red. Here is another thing on the logger i noticed coolant temperature is way down like under normal temp. and then o on top of that o2 reading is maxed and air fuel guage is maxed. now its not like i haven tried to lean it out but i get scared leaning it out past ten percent for the same exact reason fear of detonation. im gunna check my base timing tomorrow after noon and before then pull spark plugs and see whats up. it just seems so random and also check for error codes. okays guys point me in the right direction please.
i got an exhuast leak i found but it would be a mirracle if that was it .
