96gstdsm
- 808
- 2
- Aug 7, 2006
monroe,
New_York
Was driving my car to the bank with a friend. Got there and while he was going to the atm the car suddenly just turned off instantly. Not like a normal stall or anything.
Tried to turn it on and it almost went on but didn't. Tried a few more times and it did turn over just didn't start.
I tried roll starting it and nothing either. Tried multiple times again and nothing would help it start.
Would a bad isc cause this? Or what would be the best guesses to check? I could smell fuel also so I believe it is getting fuel to the engine. The MAS is plugged in, the tps is connected as well as the isc. Checked all the connectors on for the spark plug wires and all. New spark plugs. New 190 fuel pump rewired. Any ideas on what would just make the car shut off all of a sudden when it has been running fairly decently?
It has been stuttering on and off recently though. Got much worse with the stuttering when there were some 650cc injectors in the car. It would only stutter just when getting into boost.
When I had the 650's in it was unable to boost at all. Would just stutter the whole time.
