Quote:
Originally Posted by JayRolla
My mechanic has ran all setups in his 2.4 and from what he told me the 272's did nothing. He said the high rev cams actually kick in at lower rpms on the strokers. At least 280's are recommended in a stroker.
Define "recomended". All aftermarket cams are recomended, as they all will be a vast improvement over the stockers. More so than on a stock displacement motor. A bigger motor will "tame" a came somewhat, but I don't think you'll see it peak out a a lesser rpm.
If you're mechanic really believes 272s did nothing, then I would find a new one
Granted, they certainly aren't my first choice for a stroker build (i run the 101400s as the 3xs weren't available when I ordered these) but they will still make plenty of power in a good set up.
